Auteur Topic: Pentax K-01 (even de titel van het topic aangepast)  (gelezen 39922 keer)
Re:CES geruchten over nieuwe Pentax camera
« Reactie #104 Gepost op: 27 januari 2012, 17:34:40 »
Dat is wel gaaf, een huis gebouwd uit Pentax camera's  ;C
En om en om een objectief naar binnen en naar buiten gericht ?
Zodat je buiten ....
Nou ja... :-X
« Reactie #103 Gepost op: 27 januari 2012, 17:30:20 »
The new Pentax K-01 mirrorless camera is supposed to be build like a brick, literally
« Reactie #102 Gepost op: 27 januari 2012, 12:14:06 »
Nog eentje dan:
The Pentax full frame DSLR and mAPS-C mirrorless camera rumors are back. I received several new tips on those products.
After it got acquired by Ricoh, Pentax is reportedly determined to provide a full range of cameras, including a new full frame DSLR and the upcoming K-01 APS-C mirrorless camera. A Ricoh representative  recently said that they “will plug a gap in the market” in 2012. The full frame Pentax camera is rumored to be announced later in 2012 (either in May or for Photokina in September).
The new Pentax K-01 mirrorless camera is supposed to be build like a brick, literally - you should be able to place on a table in landscape or portrait position without a tripod. Pentax has said in the past that they like to do things differently:
    "if we decide to do something in this respect has to be different, and it is not easy in the current context, to do something that is different and good…”
All Pentax FA lenses will work on the new K-01 with the exception of few models.
Read more on PhotoRumors.com: http://photorumors.com/2012/01/24/some-more-pentax-rumors-full-frame-dslr-mirrorless-camera/#ixzz1kekEkQqb
« Reactie #101 Gepost op: 27 januari 2012, 12:12:03 »
Op PhotoRumors:
Here are few more details on the upcoming Pentax K-01 mirrorless interchangeable lens camera:
    The camera is designed by a famous designer
    The new 40mm f/2.8 pancake lens is less than 1 centimeter thick and my understanding is that it will work only with the new K-01 body
    The Pentax K-01 and the 40mm lens are covered with some kind of rubber-like material for better grip
    The K-01 will have an external mic output for video recording
Read more on PhotoRumors.com: http://photorumors.com/#ixzz1kejfwoVg
Offline roeland
« Reactie #100 Gepost op: 27 januari 2012, 11:59:14 »
Je zou ook kunnen denken om de camera zo te ontwerpen, dat de "ring" er al standaard op verwerkt zit toch?  ???
Dat zou technisch zonder problemen kunnen maar dan wordt de body minder vlak en als er dan toch genoeg ruimte is kunnen ze er net zo goed meteen een spiegel en een prisma innouwen.
Eh, moment.... ;)
Ansel Adams
« Reactie #99 Gepost op: 27 januari 2012, 11:40:34 »
De fabrikant zal nooit een bestaande K-bajonet op een ingekorte (= spiegelloze) body construeren, omdat je dan "per ongeluk" een bestaand objectief zonder adapter op die body zou kunnen monteren. Als Pentax overgaat op spiegelloze body's komt daar geheid een nieuwe vatting op.
André
Offline roeland
« Reactie #98 Gepost op: 27 januari 2012, 11:12:50 »
Waarschijnlijk, maar dat is iets anders dan "kan niet".
Ansel Adams
Offline Andr Kok
    • Welkom op de site van Andr Kok
« Reactie #97 Gepost op: 27 januari 2012, 11:07:53 »
André
Offline roeland
« Reactie #96 Gepost op: 27 januari 2012, 09:27:56 »
Ook fout: als deze spiegelloze camera de K-vatting zou hebben zou er niets meer deugen van de registerafstand. Kan dus niet!  :)
De registerafstand van een K-bajonet is groter (nmag ik toch aannemen), kwestie van een K-K tussenring. Dat werd in M42 tijden ook al gedaan door Zeiss, Contax, Yashica, Nikon, Canon, Yashica, Kowa en nog zo een paar kleine merken. Omgekeerd is een stuk lastiger omdat er dan optische trucs tussengeknutseld moeten worden, dat gaat niet goed komen dus de "nieuwe" K-objectieven gaan niet werken op "oude" ASP body's.
Verder is alles speculatie tot het ding op de tafel ligt, volgende week of zo...
Ansel Adams
Offline Andr Kok
« Reactie #95 Gepost op: 26 januari 2012, 13:14:23 »
Fout: Pentaxforums-lid Adam B. maakte deze zeer geslaagde impressie van hoe de K-01 er uit zou kunnen gaan zien.
André
« Reactie #94 Gepost op: 25 januari 2012, 14:59:40 »
Ja van mij ook op het autoweek forum. Toch ben ik een jaar de meest actieve poster geweest  :D
« Reactie #93 Gepost op: 25 januari 2012, 14:56:11 »
Less is more... ;C
Al jarenlang mijn motto hier  8)
« Reactie #92 Gepost op: 25 januari 2012, 14:52:30 »
Less is more... ;C
 :-X
Strikt genomen zou dat nog te veel zijn.
« Reactie #91 Gepost op: 25 januari 2012, 14:07:14 »
Ben je nauwelijk actief, ben je goed bezig...  :o
Less is more... ;C
« Reactie #90 Gepost op: 24 januari 2012, 23:55:39 »
Als Marc Newson hem ontwerpt kon je een glad en rond ontwerp verwachten met weinig knoppen. Volledig tegen de huidige retro-trend in. Daar ben ik dan wel weer benieuwd naar.
Naar mijn idee moet je wel een erg beroerde ontwerper zijn, als je een camera nog lelijker kunt maken dan wat hier voorgeschoteld wordt. 8)
« Reactie #89 Gepost op: 24 januari 2012, 23:50:08 »
Ja, Ruurd is goed bezig de laatste tijd!  ;)
Offline Soap
« Reactie #88 Gepost op: 24 januari 2012, 22:52:45 »
Leuke impressie, nu eens zien hoe de werkelijkheid er uit gaat zien  :)
« Reactie #87 Gepost op: 24 januari 2012, 17:09:15 »
Op www.digifotopro.nl is de Pentax K01 tezien.
« Reactie #86 Gepost op: 24 januari 2012, 15:58:59 »
Offline roeland
« Reactie #85 Gepost op: 22 januari 2012, 10:28:52 »
kan een systeemcamera ook spiegelloos zijn?
Ja hoor, Leitz maakt al bijna 100 jaar spiegeloze systeemcamera's
Ansel Adams
Offline egbert
  • Pentax waarheen :(
« Reactie #84 Gepost op: 22 januari 2012, 10:00:07 »
Ik zit toch meer te wachten op een eventuele k-5 opvolger ;). Systeemcamera's geloof ik wel.
Flitser: AF360FGZ II
Offline ivotjuh
  • Juggling with lenses
    • Ivo Vastr Photography
« Reactie #83 Gepost op: 21 januari 2012, 19:35:48 »
De Pentax systeemcamera op de foto is niet van Marc Newson. De nieuwe K-01 waarschijnlijk wel. Maar die kun je nog niet lelijk vinden want die is nog niet gelekt.
Dan heb ik het verkeerd begrepen  ;)
Dan maar hopen dat ie er beter uit komt te zien inderdaad >.<
« Reactie #82 Gepost op: 21 januari 2012, 18:58:13 »
Ik vind dat camera's gewoon een wat klassieke vorm moeten hebben. Een spiegelreflex hoort er dus uit te zien als een K5 en een compact als bijvoorbeeld een Optio RZ10. Ik heb niks met al die gestyled camera's die er uitzien alsof ze uit de Intertoys komen.
Offline D1N0
  • prutser
« Reactie #81 Gepost op: 21 januari 2012, 18:06:44 »
Offline ivotjuh
« Reactie #80 Gepost op: 21 januari 2012, 17:01:31 »
Die camera van Marc Newson vind ik persoonlijk ronduit lelijk. Over het algemeen vind ik Pentax wel mooie camera's hebben.
